Results 1 to 10 of 10
Recommendations for reducing heat/noise inside vehicle....
One of the winter projects I have for my 69 Camaro is to remove the front/rear seats and carpet, strip the floorpan and apply POR-15 as needed. In addition, I would like to install Dynamat, or a similar product, to reduce the heat/ noise inside the vehicle and was looking for any recomendations or tips.
Thanks in advance,
Rod
10-03-2004 #2
- Join Date
- Aug 2004
- Location
- Las Vegas, NV
- Posts
- 251
A good Dynamat alternative...
http://www.fatmat.com/
I'm going to use their floor liner in my 67.Doug
67 Camaro - Project: Retribution
"Honda: The most efficient means of converting gasoline into noise without the side effect of horsepower."
10-03-2004 #3dennis68 GuestAndrew just did an article in PHR I think about this. He will probably chime in on this. He did massive work to reduce NVH. There are tons of products for this purpose out there.
10-04-2004 #4Rod,
My guy (Tim) recommended Lizard Skin. It is a spray on product. It is both a thermal insulation and a sound deadener. Tim does some nice stuff so I have to trust him on this one. I should be getting my car back within a couple of weeks for wiring and I'll see the product then. I'll let you know how it looks. I saw one of the Nova guys had some pix on a thread I'll see if can find it. www.lizardskin.com
http://www.strangemotion.com/html/whats_happenin.html
Dan
10-04-2004 #5
- Join Date
- May 2003
- Location
- St. Charles, Mo
- Posts
- 424
Lizard Skin
Pics of my Nova interior
Above is the link to my Nova interior page. It shows the finish of the lizard skin sound deadener/insulator. It can be sprayed on, brushed on, or rolled on. I used a 4 inch roller to apply it to my center console and it went real easiy. Spraying it on does provide a better finish. I still don't have the car running so I can't tell you how it sounds.
I got it not only to cut down on noise but also on the interior temps. I applied it to the roof as well as on every panel and floor. I installed Vintage air so I'd like to make it as efficient as possible.
10-05-2004 #6
