View Full Version : what is the difference?
muthstryker
02-17-2006, 09:19 PM
what is the difference with a LQ9 out of a escalade and LS1/LS6 i know the lq9 using alot of the parts from them and it is heavier. the LQ9 is about 3500 and the ls1/ls6 are 5500. would the LQ9 be better for me since i am only 16 and im kind of on a budget or shud i save for the ls1? jsut let me know if there is anythign else im missing.
matt
rocketman
02-17-2006, 10:40 PM
lq9 is a 5.3 which is 327 cubes,ls1 is a 348.blocks are diff in the lq9 is steel.heads,basiclly they are totally diff.
nitrorocket
02-18-2006, 07:03 AM
The lq9 heads are from the 6.0. If you do the swap, only do a ls1. You will regret the other way.
The 6.0 sucks way more gas, is 100 lbs heavier, has only 9.5:1 comp, low end torque cam, huge poor flowing intake, and makes less power. Still an escellent motor, but better suited to a work truck like designed.
andrewb70
02-18-2006, 08:26 AM
The LQ9 sucks more gas because it is 6.0L and it is in a truck. On a budget buildup, there is no reason not to have the LQ9 as a viable option. If you aren't in a hurry, I would wait until a few of the aluminum block L92s start hitting the wrecking yards. Those are from the 2007 Escalades.
muthstryker
02-18-2006, 11:15 AM
ok thanks for the replies after checking into in a little more ive deiced to go with a 454 HO.
rocketman
02-18-2006, 11:26 AM
my mistake i thought the lq9 was the 5.3.
muthstryker
02-18-2006, 06:21 PM
here the link http://www.crateenginedepot.com/store/60-Gen-III-Crate-Engine-17801269-P854C2.aspx it has iron block of LQ9 and his a 6.0 not a 5.3
