View Full Version : c-4 master cylinder question on 69 camaro
69camarodave
02-14-2006, 02:59 PM
i have a 69 camaro that im putting c4 12 inch rotors and pbr calipers on the front,i have 2 questions.
what master should i use,im using the big drums in rear for now .i have the stock 73 nova master that i used with the orig front disc.
and what front studs should i order from the parts store for the front drum hubs,i assume i need alittle longer ones to work with the front rotors.
thanks in advance
dave
67LS1T56
02-14-2006, 10:15 PM
Do a rersearch on team camaro web site. But as far as I remember disk front an drum rear was a no no. One of the member's friend on the team camaro web site had a bad experience with disk/drum set up. I think it was imposible to balance the front to rear .
Also you have to use power assist. with C4
