View Full Version : 1969 Camaro Rear E-Brake Cable - Lokar help?
Brandon
02-14-2006, 10:24 AM
I am installing LT1 ('93-'97) rear disc brakes on my 1969 Camaro. What Lokar e-brake cable do I need?
I want to run my factory e-brake pedal and intermediate cables.
Would this part work (LOKEc81fu) - I believe it is available at Summit Racing?
Brandon
67LS1T56
02-17-2006, 11:09 PM
that is for their e-brake set up. You can call them with your needs.
67LS1T56
02-17-2006, 11:10 PM
That is for their e-brake set up. You can call Control cables with your needs.
69bigblock
02-18-2006, 04:36 AM
You could use a rod, 7"'s or so which would be threaded inside one end which the factory threaded cable would srew in and the other end drill a hole which the lokar cables would connect to. I bought the universal cables and had the rod made, but I was using 79 rear brakes. I recently changed them to the lt1 style. So I haven't mounted the lokar cables on the new brakes....
andrewb70
02-18-2006, 08:20 AM
I believe ATS has something for this.---------------->
