View Full Version : G-body hub
87SS
02-12-2006, 05:54 PM
anybody make a hub like the pic below for a 80-88 G-body spindle?
I would think someone has to make one for the dirt track guys
Samckitt
02-13-2006, 03:43 AM
Who makes this one & what does it fit?
F, B % G body rotors all use the same bearings. I think S-10s are the same too.
87SS
02-13-2006, 04:57 AM
Scot, It fits the 67- 69 camaro drum hub .
Samckitt
02-13-2006, 05:43 AM
Ah, I see. When I was going down the C5 brake route on B/G spindles. I simply took one of the factory rotors & had the brake surface machined off to make a hub.
Obviously doing this pushes the wheel out .25" or so, and weighs more than aluminum ones.
87SS
02-13-2006, 09:59 AM
Scot, this is Dennis (Bigthreefan) from the Monte board.
I have my "LS1's" done with the G-body spindle & the turned down rotor
.. I was just looking at other options. I can get Baer hubs for $155 each
thanks though
Samckitt
02-13-2006, 02:16 PM
I was going to have some made. But the guy wanted $300 for the pair. Instead I bought a set of ZQ8 spindles. They have the slip on rotors. And all I had to do was make the adapter bracket between the knuckle & the C5 saddle bracket. No (very little) machining was needed on the knuckle itself. Actually just a little grinding.
Scot
olds87
02-13-2006, 03:02 PM
I s it possible to use ZQ8 on 87 cutlass supreme?
Samckitt
02-13-2006, 03:05 PM
All G bodies use the same spindles from 78 - 87/88.
Scot
olds87
02-13-2006, 03:17 PM
What is the place that I can find all the information at?
Samckitt
02-13-2006, 03:54 PM
I don't know if there is anyplace that it is all documented. I have done research on this for a while. What do you want to know?
Scot
87SS
02-13-2006, 04:41 PM
ScotActually Scot. the 78-81 G-bodys uses a shorter spindle "hub" & requires a different part#/s rotor. to be on the safe side I always say 78-81 are the "same" & then 82-88:)
78-79 monte rotor..raybestos#105034
80-81 monte rotor..raybestos#105038
82-88- monte rotor..raybestos#105064
There's quite a bit of info but you;ll need to search the Rolling Chassis (http://www.montecarloss.com/ubb/ultimatebb.php?ubb=forum;f=18) Fourm
Samckitt
02-13-2006, 05:17 PM
Oh, sorry about that. I thought all parts were interchangeable from 78.
Thanks for clearing me up.
Scot
Samckitt
Are the mounts for the upper & lower ball joints different?
87SS
02-13-2006, 05:27 PM
no they are all the same in that aspect. just the actual spindle/hub area differs. the area-space between the bearings (that make sense?)
Samckitt
02-13-2006, 05:56 PM
Yep makes perfect sense. Then the S10 ZQ8 "knuckles" would still fit because the ball joints & mount locations are the same.
87SS
02-13-2006, 06:48 PM
correct:3gears:
