    Results 1 to 7 of 7
      Northern NJ
      tire sizes for a 19inch wheel?
      im thinking of doing an 18x8/19x8 or 19x9 wheel combo on my daily driver, anyone have any suggestions for a tire size for the 19inch wheel? i was thinking maybe a 275/40r19??? im gonna run a 245/40r18 up front but i want the rears to look somewhat proportional to the front. any help or pictures is greatly appreciated.
      LSx-powered 81 Mustang...
      Jacksonville, NC
      I say do it, I plan to run the same size tires and wheels plus 1. In other words 19s and 20s on my camaro like prodigy. Search for prodigy on here and maybe a few pics of it will come up from sema.
      Derek
      rim size
      Hey James, Sweet looking car, I have an 83 Malibu Wagon that I am looking to put a set of rims on. I was wondering what the ones on your car in the picture are. What size and backspacing are you running because it has an awesome looking stance. Everyone seems to have a different opinion on what you can fit on these G-Bodies........Thanks
      Jim
      Quote Originally Posted by lt4malibu
      The 275/40/19 may be a tad on the tall side. I would compare it side by side with a 295/35/19 with that front tire. You would need to increase the rim width to ten inches.
      Northern NJ
      well the 19's are going to go on my 99 2wd blazer, so i was kinda hoping to have a little sidewall and i dont think a 10inch wide wheel will fit, there arent many tire companies that make tires for 19's and sizes are kind of limited(at least from what ive found) i may just run an 18x9 out back, im not sure yet. thanks for the input so far though!
      Northern NJ
      Quote Originally Posted by CHROMAHOLIC
      Jim
      they're Budnik M5 fatlip's, 18x8 up front(5inch backspace) with a p245/40r18 tire, 18x9 in rear (4.75backspace) p275/40r18 tire. they fit perfect, dont rub up front at all.
      Thanks James, I appreciate the info on the rims. Right now I only have 15x7's on the car but I am planning on putting about $10,000.00 into the car within the next few months. I'm going to do rear discs, complete Hotchkis suspension including sway bars, rims and tires. I want to run an air ride Technologies kit so do you think I would be better to run 18x8's all the way around with a 4.5 backspacing so that I can set down with the air out of it. I also want to run a new LS motor in it but just not sure whether I want to get into all the work to change it until next winter. It has a 350 in it now with a mild cam, headers, pete jackson gear drive. I have a 3:73 8.5 Grand National rear end for it that I will put in when I do the brake and wheel upgrade. I enclosed a pic which I modified the rims and brakes on just to see what it will look like.....Thanks James
      Jim
