Results 1 to 12 of 12
- Join Date
- Sep 2004
- Location
- Macon, Georgia
- Posts
- 19
Question about big calipers and braking pressure.
I'm new here and this is my first post. I have a question that has been bugging me for a while. Here goes.
The biggest old technology, one-piston calipers, like the JD7 option on the old Suburbans have a 3-5/32 inch diameter piston. Doing the math yields 7.82 square inches in surface area.
The big new technology, two-piston C5 calipers have 1.75 inch diameter pistons. Doing the math yields a total of 4.81 square inches in surface area.
Clearly, the JD7, one-piston calipers have more surface area, which means more braking force with the same amount of fluid pressure to the brake pad. Force = Pressure x Area. Given that, why does everyone gravitate toward the dual piston calipers (including the automotive industry)? Is it that they are easier to adapt because of the cage style bracketry? Is it because the pads are a little bigger and perhaps give a little more frictional resistance? Maybe there are better choices for pads. Any insight would be appreciated. Thanks.
