Results 1 to 1 of 1
02-05-2006 #1
- Join Date
- Jan 2006
- Location
- SoCal
- Posts
- 18
69 Mustang front disc brake upgrade?
I will be upgrading the front disc brakes in the next few weaks. I have stock front disc brakes right now. I had been planning on the 6 piston set up that Global West sells, but I cannot afford because of other work that has to be done to the car right now as well. I like the zero offset Wilwood 4 piston Dynalite set up that can be had for less than $1000.00. I also had considered a Trans Am Boss 302 set up but I like the weight savings of the Wilwood set up, "unsprung" weight is always the best weight to loose, plus the Wilwoods look so much better than old Kelsey Hayes 4 piston calipers. I do not like the look of Baer brakes so I am not considering them. Any experience, advise or input would be appreciated.
Mike
