    Results 1 to 7 of 7
      Laramie, WY
      new electronic transmisson to a BOP
      I am working on getting a buick and would like to put in an electronic transmission in it. Does anyone one know if the new trannys have the BOP bolt pattern,am I looking at an adapter or just SOL. I am wanting an electonic transmisson so I can use the paddle shifter on it and have O/D.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
      Jan 2003
      Arizona
      Tim,
      Give Bowler Transmissions a call and ask for Mark. Says an adapter for that application is about $240. Crank to flexplate spacer, bellhousing adapter and hardware. Please tell him that Steve at Twist Machine referred you.
      http://www.bowlertransmissions.com/
      RR#4 Box 148
      Lawrenceville, IL 62439
      Main Phone: (618) 943-4856
      Fax : (618) 943-3690
      ________________
      Steve Chryssos
      Cornettsville, ky
      200r4
      Cornettsville, ky
      200r4 usually have both patterns....they make adapters for chevy to bop ........what kind of buick if its a nailhead you will have to have and adapter for any other tranny
      ......look at v8buick.com they have all the infor on buicks you need
      Aug 2005
      Patterson, NY
      The 200-4R is not electronic. I don't think there are any BOP pattern electronic transmissions.
      Miami, Florida
      Thanks for the thread....
      ...and thank you Steve for the refferal.
      I called Mark at Bowler and ordered an adapter and a pan for the 4L80E I'm putting into "Eternity". Now I need to find a neat way the shift that same tranny....hmmmm
      Kevin.
      69 Firebird "Eternity"
      Cornettsville, ky
      Quote Originally Posted by GetMore
      my bad it an od just not full computer controlled......the tcc is electronically controlled
      for a 350/400/430/455 you can use those adapters under 100 bucks from summit jegs etc
      401/425 cost about 350 bucks www.transmissionadapters.com or www.nwspeed.com
