View Full Version : I can't get no... sparkisfaction
Matt
02-04-2006, 02:38 PM
1. Replaced the coil.
-No spark
2. Coils only getting 6.3 volts
-no spark
3. New Battery
- no spark
4. 3 wire leads, all of them are getting a positive signal
.15, 12, 9 respectively.
5. Tried hooking the leads directly to the battery.
- No spark
6. Checked the coil wire from the coil to distributor, getting 3-4 ohms. One of the leads fell off, but we put it back together, still getting resistance through it via the volt tester.
....Gonna go eat now, PLEASE help :guilty:
Bill Howell
02-04-2006, 08:58 PM
What we working on here Matt? Type car, ignition?
Matt
02-05-2006, 04:17 AM
Damn, I'm sorry... details right.
68 camaro, points type distributor... Fortunetly I was finally able to get ahold of a friend of mine who after 10 minutes had the thing running, and after another 20 had her running like a champ.
Steve68
02-05-2006, 06:40 AM
Bad points and condenser???
Bob Johnson
02-05-2006, 08:04 AM
call Mr. Sparky!!!! If you need a restaurant guide call Howell...put the end of a plug wire to the head of your pud..it'll start sparking then for sure..that's the way the Murphy's LAW works..
Matt
02-06-2006, 03:05 AM
Loose wire in the distributor, we screwed up the firing order, because my friend that was reading the book is apparently illiterate. Basically a whole lot of problems from the 'how does a carb work' generation.
EFI69Cam
02-06-2006, 02:27 PM
That reminds me of a guy who said he used to keep a magneto with wires still attached on the shelf in his shop. The nosy customers would pick it up and give the shaft a spin with the wires hanging down right in front of their "area". He said it provided much amusement as you can imagine.
