View Full Version : primer question
lt1chevelle
01-21-2006, 11:58 AM
iam useing featherfill g2 on my car can i put bondo on top this primer? also i heard it was a good ideal once i sprayed the whole car and everything this straight that it is a good ideal to spray a uerathan primer over top it becuase u cant wet sand the featherfill and i could wet sand the other primer and u would get a smoother finish
thanks chris.
mikey
01-24-2006, 08:44 PM
I'll ask my paint rep tomorrow. I'm not familiar with feather fill but we spend 20,000 a month with him so I know I'll get you the right answer
projectPONY
02-01-2006, 07:49 AM
yes, you can apply plastic fillers over the Feather Fill. both are polyester based products.
always, and I do mean always use a urethane primer after before topcoating. if you don't the polyester resin in the primer filler and plastic filler will suck up the paint like a sponge and you'll be back at square one.
good luck.
