View Full Version : Offset?
Norwoodx55
01-19-2006, 04:28 PM
Could somebody explain wheel offset to me. I thought it was the deviation from center. Such as an 8" wheel with no offset would have 4" backspacing. Recently at Disco Tire, they told me that the 8" wheel I was looking at had zero offset and 4.5" backspacing. Now I am confused.
Thanks, Brett
baz67
01-19-2006, 05:01 PM
You are correct in both accounts. Confused even more? Wheel width is measured from the tire bead surface to tire bead surface. Backspacing is measured from the wheel lip which happens to be around .5" out from the bead surface. That is where the extra bit comes from.
TonyL
01-19-2006, 05:19 PM
up in the top of the forum under "wheel tech questions" is the following link.
it describes in great detail every thing you wanna know
check it out.
how to measure offset, backspacing, etc. (http://www.rsracing.com/tech-wheel.html#patterns)
good stuff in there. should answer all your questions.
Norwoodx55
01-19-2006, 10:05 PM
Thanks for the help, it is all clear as mud now. :hammer:
Brett
DeepBlue68
01-19-2006, 11:54 PM
Wow, I didn't know that. Good thing somone brought that up since I'll be doing all my BS/offset measurements over spring break.
