    Results 1 to 4 of 4
      Aug 2005
      wilwood clearance issue with LR shock solved
      i have seen a lot of posts with people having problems with the rear mount wilwood calipers on first gens. i had the same problem with mine. i assembled the housing out of the car and then during install i found the lr shock problem. i am using 3/16 hard line from the center of the housing to each side. when the line gets to the u-bolt i am using -3 braided stainless flex line. with the lr i had to use a 90* fitting off the hard line aimed towards the rear of the car around the back side of the shock with a 90* fitting towards the front of the car which attached to the fitting in the caliper which is a 90* facing the rear. sounds a little confusing but its very clean looking and i have about 3/8" clearance to the shock. i hope this helps someone else.
      Sep 2004
      pittsboro, nc
      have any photos?
      Medford, OR.
      Quote Originally Posted by 69ozz
      Thanks for sharing this!! There are many on here that will be glad to know this. I will be sure to reference you post from time to time!
      Laramie Torres
      Aug 2005
      shane, i will try to post some pics by this weekend.
