View Full Version : Spring Rate On My Daily?
Marrk
01-18-2026, 03:24 PM
Hi. I'm new here. This is my First Post. I know nothing about suspensions (or about of anything else if you exclude tequila), and I have always considered suspension tuning a "dark art" that is best left to the experts. But I'm a car (and motorcycle) guy, and I hate to let anyone touch my car, even if it is just a beat-up daily driver. So, I'm here to learn about suspension and see if I can maybe upgrade what I have.
My question for today is this: Does anyone here happen to know what the spring rate is on stock springs (front and rear) on a 2013 Honda Fit Base Model with manual transmission? I am unable to find this information on the Internet. It may be marked on the spring itself, but I did not see it the last time I had the wheels off.
Thanks. :)
Olds.PhD
01-18-2026, 03:38 PM
You'll find better answers here:
https://www.fitfreak.net/forums/
Marrk
01-18-2026, 03:57 PM
Thanks, Doc. Been there for ten years. Posted my question there several days ago. 38 Views, 0 Replies.
Olds.PhD
01-18-2026, 04:18 PM
Maybe try a search first. I'm seeing quite a few threads about that very question:
https://www.google.com/search?q=fit+spring+rates+site:www.fitfreak.net&client=firefox-b-1-d&hs=XqBp&sca_esv=b4143623d72f6fa3&sxsrf=ANbL-n7FE1MhYhiBq7rYnm9l_sWm-UK5fw:1768781356162&sa=X&ved=2ahUKEwibmq2DqJaSAxUUh-4BHZ9uLdcQrQIoAnoECBgQAw&biw=1707&bih=906&dpr=1.5&aic=0
Next options are Reddit and/or Facebook groups dedicated to the platform.
You are very likely the first person to ever ask a question about a Honda Fit on this forum. If you're not getting answers on a dedicated forum, you're unlikely to get them on this one.
Marrk
01-18-2026, 04:33 PM
Thank you, sir. Duly noted :)
One last question: Spring rates are marked on the parts themselves, correct? If so, then mine should be marked somewhere. I'll just have to find it. Unless it was a label, and the label fell off.
Thanks, again. :)
Hotwire
01-20-2026, 02:57 PM
Look up autocross or SCCA groups in your area on Facebook. Someone they're might be able to help, if not know someone with a set of scales so you can corner measure your car and have a better starting point for spring rates.
Marrk
01-20-2026, 03:57 PM
Thank you. That's good advice. The Fit is often used in autocross. :)
JustJohn
01-21-2026, 05:51 AM
I am very good with the interwebs:
For a 2013 Honda Fit (GE8) on stock suspension, all trims use essentially the same stock spring rates, and the best available measured data says:
Front spring rate: ≈ 1.7 kg/mm ≈ 95 lb/in
Rear spring rate: ≈ 2.0 kg/mm ≈ 112 lb/in
These numbers come from owners who’ve had the OE springs measured or back–calculated them; Honda doesn’t publish spring rates in the service manual. A FitFreak thread cites 95 lb/in front, 112 lb/in rear for 2009+ Fit (GE8), which includes the 2013 model year.
So for your 2013 Fit base manual, you can safely work with:
Front: ~1.7 kg/mm (95 lb/in)
Rear: ~2.0 kg/mm (112 lb/in)
Marrk
01-21-2026, 08:27 AM
Thank you, John. I will make note of those numbers. :)
