View Full Version : 'Emma Kate' 1969 Camaro
69RSLT1
12-03-2025, 02:03 PM
I have 3 pro touring builds in mind, one for each of my granddaughters. The first is Emma K8, a 1969 Camaro RS/SS. The second is 'Kennedy', a 1973 Trans Am, and the third will be 'Madison', a 1974 Corvette Convertible. If I'm still around, a 4th will be for my first grandson. 'Harvey' will be a mid engined 1969 Mustang Hatchback.
I give you: Emma K8
What we have now:
All new sheet metal body with DSE mini tubs and partially shaved firewall.
DSE Hydroformed Subframe with Single adjustable coilovers
DSE Subframe Connectors
DSE Quadralink Rear
9" Ford True Trac 3.70
Wilwood 6/4 piston brakes
Planned changes coming up in Feb:
Door handles shaved
Drip rails shaved
Flush Glass
Working right now on
C7 Z06 Carbon Ceramic Brakes
2014 Mercedes CLA dash
Engine Build
Eventual Specs: Subject to change and will add as we go.
Engine:
TSP Resleeved LS 5.3 to 427 big bore
RHS Pro Elite LS7 Heads with 2.20 Ti intake and 1.615 Stainless exhaust, 400cfm
BTR custom cam for 3000 stall converter, targeting 650 @6500 on pump gas
Jesel Pro Aluminum Rockers
Carbon pTR LS7 intake with 105mm TB
Transmission: ZF 8HP70 with 3000 stall converter
Maxx ECU controlling engine and trans
This is intended to be a high tech build, with features like paddle shifting and ABS.
More details to come but I gotta get to work for now.
219066
219069219070219067219071219068
69RSLT1
12-03-2025, 02:59 PM
4 packages arrived today!
In the crates are the TSP shortblocks. I stayed up until midnight on Black Friday to score these. While I had an immediate need for the -2cc piston unit for Emma Kate, I couldn't pass the opportunity to get the -18cc dished version for the Whipple 427 going in Kennedy. A $9k shortblock for $6500.
The Painless engine harness arrived as well as the Racepak 12.3" dash. The harness is setup for a GM ECU, but to save 2 grand, I don't mind repinning it for the MaxxECU.
I've had these heads laying around for 8 years. They were on my C6 Corvette Road race car, sequential shifting at 7500 RPM. Glad I hung onto them.
219075
219077
219076
69RSLT1
12-11-2025, 10:52 AM
Well, the Carbon pTR intake is certainly a no-go.
With all the conflicting info out there, I just had to see for myself.
219103
69RSLT1
12-11-2025, 11:01 AM
Gotta stop sometime.
Had to utilize a different spindle than the DSE, since they do not offer a C7 brake option.
Some work to do to get the steering adapter mounted, but not a huge task.
Yes, the brake sensor will be wired to the ECU to present an alarm on the dash.
WARNING: Will require the use of 18" wheels.
219105
Aschle
12-11-2025, 12:53 PM
This is going to be another awesome ride !!!
ryeguy2006a
12-15-2025, 01:47 PM
That is a massive rotor! I forget how big those are.
dhutton
12-16-2025, 05:02 AM
Impressive build. What spindle did you use to get those C7 calipers to fit?
69RSLT1
12-16-2025, 08:27 AM
https://store.partsshopmax.com/shop/Corvette/ss/C7SAKN.html?srsltid=AfmBOook38HNG3HzqKutL0q2XinC_3 MYwvJPk0bEePGMBKyEQm_ugjVa
69RSLT1
02-22-2026, 10:44 AM
Still waiting to get into the sheet metal shop, but busy on several fronts.
Installing the dash and steering column, from 2014 Mercedes CLA
219809
Out with the old and in with the new...
219814
219813
219815
219816219818219817219819
Seats (from 2012 SLK), recovered in the interior scheme.
219820
jaybee
02-28-2026, 02:44 PM
Wow, that is going to be an awesome car.
