    Results 1 to 4 of 4
      Oct 2025
      Ridetech Tru turn, Can I use OEM style tie rods instead of the Heim joints
      Hello
      Stumbled upon a used complete ridetech Tru Turn setup, the newer style. I´ve been reluctant to go this route in part because of cost but mostly because of the Heim joints.
      (and also because it´s mostly a street car) But when doing some suspension simulations for fun, it turns out the tall drop spindles are actually great for geometry (roll center position & movement, because of the more favorable lower control arm angle, plus the more obvious and perhaps a little aggressive camber gain) but with everything else untouched also very terrible for bump steer...and wheel fitment... Hence my interest in the Tru Turn setup.
      Now this setup is used and might be priced right but I´m pretty sure the Heim joints are no longer tight and needs replacing as they will frequently if used on the street in the occasional bad weather.
      Surely there is a good reason that they only come with Heim joints other than for adjustability? But I cannot find any info regarding this in the googlemachine...
      So... Is it possible to use OEM style tie rod ends instead of the Heims? I´m aware that First gen Camaro Outers is probably not correct length or maybe not even correct thread size, but I am prepared to do a little digging to find something that fits (or fab up custom adjuster sleeves, or both...). I´m also aware that I´m loosing adjustability and may get less than optimal bump steer performance, but I´m willing to give it a try if there are no other obstacles, worst case I will just divert back to Heim/R joints.
      I´m using GW Control arms, Brakes are Corvette C3 (repop JL8 caliper brakets) Wheels will be Corvette 15X8 Rallies, Power steering box is one of the fast ratio/High effort ones from a second gen camaro iroc/z28 (XH). Back end will be sitting on Hotckiss 1,5" lowering Leafs with possibly a 1" lowering block.
      Mountain Springs, Texas
      R joints are not available for that application afaik. I went through that with Brett years ago on my TruTurn setup. I live on a dusty road and the heims got noisy in no time.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2004
      Santa Barbara, Ca
      It would be nice if they made an R joint for that application. It looks like their new first gen subframe uses the same heim joints as the TruTurn, which is a bummer.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      Nov 2018
