    Results 1 to 10 of 10
      Jun 2020
      Dahlonega, GA
      69 Camaro DSE 4 pt Cage
      Thought I'd share the 3D printed covers I made for the roll cage as it goes thru the package tray - this is a 69 Camaro project I'm currently working on. They're slightly larger than the tubing and slip into place before the cage goes in.
      Name:  Screenshot 2025-09-07 9.10.54 AM.png
      Mountain Springs, Texas
      Those are nice!
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Aug 2022
      SoCal
      So, these look great, but something to consider before finalizing it: what material are you using and is it UV resistant? That area is going to see a lot of sunlight and certain plastics will not do well in that application. You could paint them, but as the paint breaks down, that area will be a royal pain to try to repaint without removing glass.
      Oct 2016
      would be cool if these were split down the middle allowing installation or removal after the bar is installed.
      Maybe a ship lap joint you could glue together or something like that
      Jun 2020
      Dahlonega, GA
      It's a high temp UV resistant resin - I don't have the resin spec handy, did it at work. But, I thought about that and if it fails over time I'll cut it off and design another one that is split. The car doesn't see a lot of sun by any means, I guess time will tell.
      Oct 2007
      Nice work . !
      67 Camaro In progress
      Jun 2020
      Dahlonega, GA
      Here's how they turned out, installed the cage today.
      Name:  Screenshot 2025-09-07 9.15.41 PM.png
      Jun 2020
      Dahlonega, GA
      Thanks...appreciate that!
      Normal, IL
      Yes, next step would be to create a 2 part snap together and then the following step is to offer it covered in alcantara. Just kidding, they look great!
      Jun 2020
      Dahlonega, GA
      Hey....thanks. Actually, I've been working on that split part design that would glue together. Might be a while before it's done, I'll follow back up with some pics when I have something.
