    Results 1 to 4 of 4
      Aug 2025
      Lakeland, FL
      Ridetech Tru Turn with a BBC engine
      Good morning all,
      I am looking for feedback on oil pan options for a BBC in a 69 Camaro using the ridetech Tru Turn steering. I am considering using the Chams pans 207 oil pan for a little added capacity and this pan does not have any kick outs that seems to cause clearance issues with the Tru Turn steering system. Any feedback would e greatly appreciated.
      Thank You,
      James
      Jun 2020
      Dahlonega, GA
      I'm about a week or two away from installing a big block in my 69 subframe to check clearance on the oil pan. I have no idea if it will fit with the tru turn components, I've got a stock pan on the engine for now just to see if it works and how much clearance there is. I'll post some pictures once I get everything setup.
      Jun 2020
      Dahlonega, GA
      The stock big block oil pan is nowhere close to fitting with the tru turn setup.
      Jun 2020
      Dahlonega, GA
      Found a Milodon pan that fit - now on to the exhaust issues.
