View Full Version : Holley Terminator X wire port
HotRod47
07-29-2025, 09:51 AM
Hey there,
I'm in the middle of a build on my 51 Chevy Pickup and working on body work/fabrication. I plan on running Holley's Term X wire harness, and so I know I need to go through the firewall.
My question is, how big a hole do I need to have to pass it all through? Also, what are some of you using for a port to run it through that looks good and functions well?
Also, if you could share where you placed the port in relation to the engine so I can get ideas.
Glenn
Tim C
07-29-2025, 10:21 AM
On my 67 Ford Fairlane I have the Terminator X wiring coming out dead center of the firewall right behind the engine. I used a ron Francis ga50 oval grommet made for fox body mustangs because my firewall has a oval knockout the same size where factory AC lines would have exited. I want to say the id of the grommet is about 1 or 1 1/8".
I have the ECU mounted above the right kick panel and had plenty of wiring available.
dhutton
07-29-2025, 01:19 PM
https://protouringstore.com/products/holley-terminator-x-x-max-firewall-bulkhead-grommet-universal?srsltid=AfmBOorPEjFbR_AXryOoUn89HsaX2DJB YB9Mqu28tsSHhJglAm65dLsm
There are other versions out there. Google Terminator firewall pass through.
