    Results 1 to 7 of 7
      May 2016
      Switching from Dakota Digital to Speed Hut
      Need some help guidance on switching my Dakota digital gauges to Speed Hut gauges. I’m using a Holley terminator x ECU and trying to determine what i need for the ecu to talk to the gauges.
      Jacksonville, FL
      Probably going to have to run the Speedhut senders. I don’t believe there is a “BIM” module for the speedhut stuff.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Nov 2018
      I've never used or talked to them, but you might look at these guys.
      https://shop.classicinstruments.com/...3ZEf.8FITMLjg4
      It looks like Holley likes them though, because Holley bought them.
      https://www.holley.com/blog/post/cla..._installation/
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Apr 2019
      Louisville, Kentucky
      I used the speedhut gauges with GMPP ecu and harness. They plug in to a OBDII port or Canbus signal. You may check with Holley about compatibility, if I remember correctly they want you to use Holley’s version of gauges.
      - - - Updated - - -
      Sep 2013
      Houston, TX
      Custom SpeedHut Gauges
      I chose SpeedHut gauges for my 442 convertible project, but I still have the '72 Olds engine so I used the analog senders not OBDII or Canbus. SpeedHut sells speedos in Canbus/GPS/VSS versions and tachs in coil/Canbus versions. My goal was accurate gauges, and add a volt gauge but I also wanted to retain the original look. SpeedHut allowed me to customize the gauge faces to resemble the factory gauges. Here's some pics
      Rodney
      Name:  IMG_7742 copy.jpeg
      These are the oversized 4-1/2" diameter gauges. For a small design fee, SpeedHut allowed me to customize the ticking to fit within the stock bezel.
      This is the final result. You can choose from about 30 different day/night color combinations. I chose blue because it more closely matched the Olds dash lighting.
      Rodney Meyers
      72 Olds 442 Rest-mod clone
      Jul 2008
      Quote Originally Posted by Vimes View Post
      Don't go basing your purchases on what Holley "likes". They were bought out by a private equity firm and are on the hunt for making money, not making people happy.
      https://www.goapr.com/blog/post/sent...ance_products/
      *Jeff*
      Nov 2018
      Quote Originally Posted by Hotwire View Post
      No worries, I based it on the OP looking for something that will work with his Holley ECU.
      2021 Durango R/T
      2005 Dakota beater
