    Results 1 to 6 of 6
      Dec 2008
      Lincoln CA
      Baer brakes w/ Baer or Wilwood Master Manual Setup
      I did a search and I'm not finding opinions from real world experience on this topic (differences between the two). I prefer the looks of the Baer Master although performance is more important with this topic, obviously. From what I understand you want a smaller bore size for a manual setup (not sure if this is accurate, looking for advice). That said, Baer offers a 15/16", 1" and 1-1/8". Wilwood offers a smaller 7/8" in addition to the same sizes as Baer. Does the 1/16" smaller bore of the Wilwood perform better or is it not noticeable between the two Master cylinders?
      My brake setup:
      Front: Baer PRO+ 14" rotor with 6P caliper
      Back: Baer 13" rotor with 4P caliper
      Scottsdale, AZ
      I was at the same X roads before deciding to go with a I booster. I called and spoke to Baer and they recommended a 15/16 piston master cylinder on manual breaks. I would stick to their master cylinder on their brake kit.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      May 2009
      What is your feedback on the ibooster?
      Scottsdale, AZ
      Quote Originally Posted by JuStBlAzIN View Post
      I don’t have it yet. See my thread in disk brakes
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Dec 2008
      Lincoln CA
      Quote Originally Posted by Cdog View Post
      You mention that you would stick with Baer, Is that because you have experience with a manual configuration and have used both Baer and Wilwood and prefer the Baer MC? If so, what is your reason (i.e. initial bite, pedal effort, modulation, feedback/feel, consistency, etc.) behind choosing the Baer MC?
      Scottsdale, AZ
      Quote Originally Posted by 1daychevelle View Post
      Should you have an issue. the manufacturers will point fingers at each other. Baer engineers for their systems and the like. It's not an absolute but it's a good rule of thumb. What's your time worth fixing problems you didn't know existed? You can't always stick to the same brand but when you can I recommend it.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
