    Results 1 to 20 of 20
      Nov 2018
      C5 Corvette spindle arms with dropped steering arms?
      Does anyone know if such an animal exists? For my project we're going to need to lower the steering rack a couple of inches and we'll need to lower the steering arm on the spindle arm to match. As you can see here it comes out in line with the hub assembly, and I need one that will put it 2 to 3 inches lower. I'd prefer one that is not a drop spindle as the ride height is being built to where I want it with stock parts. It can be adjusted if necessary but I'd prefer that not be needed.
      Stock
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Des Moines, IA
      Cut them off, bolt on new billet ones:
      Feb 2025
      Dallas,Texas
      Yes, aftermarket companies like Hotchkis, Speedtech, and UMI offer C5 Corvette spindle arms with dropped steering arms or adjustable steering arms that can accommodate your needs.
      Nov 2018
      Quote Originally Posted by marolf101x View Post
      Interesting. Where did the billet pieces come from?
      2021 Durango R/T
      2005 Dakota beater
      Des Moines, IA
      The image is from this thread I found via google:
      https://www.corvetteforum.com/forums...les-on-c3.html
      I’ve seen a number of bolt on arms, mostly from companies using the OE knuckle and making a steering arm to fit their design.
      Feb 2025
      Dallas,Texas
      Sounds good
      Oct 2005
      Long Island NY
      Quote Originally Posted by kawasakii View Post
      None of these companies make this. Does anyone know where those dropped arms came from?
      Peter Bergman
      71 Dart GT, Stroker SB, Built For The Turns!
      Sep 2010
      Beach Park IL
      Roadster shop, DSE, Morrison all have some version of that steering arm. I would be surprised if any of them will sell the just the arm but their (RS and DSE) spindles/uprights should be a direct fit for the OPs application.
      Donny
      Nov 2018
      Thanks. I'll take a look and see what they're willing to do. At the moment, the plan is for the shop to use the existing spindles, chop off the steering arms and make a set to bolt on. They've done this a few times in the past, but it's always better to use a built for purpose part than a modified part.
      2021 Durango R/T
      2005 Dakota beater
      Jul 2026
      Kentucky
      Did you find any arms that bolt on to the C5 spindles. I made my own adapter but the arms I had to use an are a straight 5/8 bore. Name:  IMG_4829.jpg
      Nov 2018
      No. The plan is still for the shop to chop and weld my existing spindle arms.
      2021 Durango R/T
      2005 Dakota beater
      Sep 2010
      Beach Park IL
      Good lord, don't do that.
      Donny
      Jul 2026
      Kentucky
      Quote Originally Posted by Vimes View Post
      Here is your best option. It took me a very long time to get these part numbers. And I have their front suspension under my car. Lol. You will have to go through the tech department at Detroit Speed to order these. The sales people won’t know the part numbers and they are not in any of their parts catalogs.
      9309001 and 9309002 These are for the left and right bolt on steering arms. You will need the bolts for for them too. The taper will match their tie rod ends.
      Let me know how it works out. It’s hard to believe that all the manufacturers keep such a tight wrap on these arms. I bet they could sell a ton of them if they advertised them and helping others be much safer too.
      Sep 2010
      Beach Park IL
      How long ago did you purchase those arms?
      When they were still under the Holley umbrella, those were unavailable by themselves and had to buy the whole upright to get the arms.
      Donny
      Jul 2008
      With the popularity of C5 setups, there aren't any companies that make extended length ball joint or heim tie rod ends?
      *Jeff*
      Nov 2018
      Thanks TBill, that information is now on my project sheet. However, while I apprecate the information I doubt I'll use them. Since this is such a one-off project I'm still going to go with the shop modified spindle arms. All I'm concerned with at the moment is the shop getting the truck lined out and back into my hands, and welded steer arms gets me that. As long as the welded piece allows for everything to work correctly, with full articulation and no bump steer, I'll be happy with it.
      Before the truck hits the road though, I'll compare the measurements with the previously listed parts. If none will work, I'll take the modified spindle arms to a CNC shop and use them as a model for a new set. Cut and weld will be fine to get it back to my shop, but not for the road.
      2021 Durango R/T
      2005 Dakota beater
      Jul 2026
      Kentucky
      I just received that information last week. I have been trying to buy them for years but couldn’t get anywhere. And maybe you still can’t get them. But maybe having a serial numbered clip with your name associated with it might make a difference. Don’t know. I just didn’t want to see someone trying to drive something on the road with a welded on arm. Which I’m glad he verified that wasn’t happening.
      Nov 2018
      Quote Originally Posted by TBills66 View Post
      Ehh, I get tunnel vision sometimes. I've been so focused on getting my frame done and truck back that it's almost become the end game itself.
      2021 Durango R/T
      2005 Dakota beater
      Mountain Springs, Texas
      Quote Originally Posted by Hotwire View Post
      Like this?
      https://afterdarkspeed.com/product/8...bumpsteer-kit/
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2026
      Kentucky
      Quote Originally Posted by dhutton View Post
      The bump steer kits don’t drop the arms far enough.
