View Full Version : 1969 Camaro Project For Sale
Just_a_69
01-31-2025, 08:48 PM
1969 Camaro Project For Sale - SOLD
-Brand new LS9 with speedtech dry sump oil pan
-Moroso remote mount oil filter
-Custom Peterson dry sump oil tank with added capacity, fluid sight glass, & temp. gauge
-GM Engine harness and ECM
-Brand new LS9 acc. drive (discontinued)
-Concept 1 low mount AC compressor
-Kong 2650 blower (used) 2.35 pulley
-Custom C&R supercharger bricks and spacer (40% larger than stock) or Kong Bricks (stock height)
-XCFM intercooler brick inlets
-DSE stainless 1 7/8” headers (wrapped in black)
-DSE motor mounts
-Autorad 850+ HP radiator, oil cooler, heat exchanger, condenser, fan package
- Black Rick’s Stainless tank w/ 3 525 pumps (e85 capable 1000+ HP)
-FORE fuel filter
-Fragola black PTFE fuel lines
-DSX fuel rails
-T56 magnum trans
-QuickTime Bellhousing (scatter shield)
-DSE Subframe with custom tie down hooks & fresh Powdercoat
- DSE Quadralink rear suspension
-DSE Quadralink lower link reinforcement kit
-9 inch rear axle w/ locker and teflon coated nascar 3rd member, Dutchman axles, 3.89 ratio
-DSE mini tubs
-DSE Weld-in subframe connectors
-DSE transmission crossmember (discontinued)
-Weld-in Fuel pump access plate
-DSE half-height body mounts
- Bowler weld-in trans tunnel
-Hurst white lightning shifter
-Custom 8 pt. Roll cage with door swing-outs, removable downtubes and removable harness bar
-rear seat delete/firewall & dusold carbon fiber rear seat delete
-smoothed firewall
-raptor lined bottom of car
-wilwood 14” brakes front and rear
-Wilwood brake and clutch pedal
-wilwood brake and clutch master cylinders w/ proportioning valve
-IDIDIT tilt steering column
-NRG removable steering wheel adapter
-Sparco steering wheel
-Eddie motorsports black billet tail lights
-Fesler billet Trunk Hinges (black)
-Ring brothers billet air frame hood hinges (black)
-New front and rear windshields
-Anvil carbon fiber hood with carbon fiber heat extractors
-Anvil carbon fiber fenders (1.5” wider than stock)
-Anvil carbon fiber front Valence, splitter, header panel, cowl panel, rear deck lid, rear spoiler, dash, A-Pillars
-Anvil fiberglass front inner fenders and fender extensions
-Forgeline 18x10.5 & 18x12.5 black lip w/ graphite grey centers and barrels
-315/30/18 & 335/30/18 BFG Rival S tires
-Anvil carbon fiber fenders braces
-Anvil carbon fiber 2nd gen side mirrors
-Anvil carbon fiber rear view mirror
-Anvil carbon fiber door handles
- shaved drip rails
The bad:
- One of the 2 recaro seats caught fire while welding
-Started widening the quarter panels to match front fenders, haven’t finished and still needs work OR quarter panel replacement
Needs:
-Clutch (sold the stock LS9)
-Injectors (Sold stock LS9)
-Gauges
-Interior (door panels, headliner, etc.)
-Drive shaft
-Body & Paint
-Body harness
-Door glass
-Fesler flush glass (optional)
-Headlights
I know there is other misc. stuff I have and misc. stuff I’m missing.
Gilroy, CA
SOLD
216043
216049
216058
216051
216050
216052216053
216054
216055
216056
216057
216060
216059
216061
216062
216046
216063
216064
216065
216066
216067
216068
216069
Jason_Aschle
02-07-2025, 08:08 AM
Beautiful build !!! Looks to be priced for a quick sale. Best of luck with it !
Jason
Just_a_69
02-07-2025, 09:05 AM
Jason
Thanks!
