View Full Version : Howell Engineering LT4 harness not working
calvin
01-31-2025, 02:10 PM
Hi guys. Got an issue with a harness I purchased form my LT4 swap.
I called howell engineering and told them what I was building. LT4/4l80e swap into a 56' pickup.
The guy there said no problem, we'll build you a harness and ecu for your application. You'll just need to get a stand alone TCM.
Fast forward to this month. We got everything installed and the engine has about 25% power. Got a tuner involved and he logged into the ECU and said it's in limp mode and it looks like it's due to no VSS sensor signal.
Call Howell and they say " gee..yeah, not really sure what's happening as we've never built one for a SC application". So now i'm paying a couple guys to try and do their R/D to find a work around. Needless to say i'm pissed, I would have never bought this crap if I had known I was the guinea pig.
Anyone ever run across this issue doing this swap. Did you find a VSS work around or figure out how to properly pin in an old 2 wire VSS instead of a 3 wire?
Thanks for any help
dhutton
01-31-2025, 05:26 PM
I am not sure if your case is the same but I have used this with good results. Sorry if I misunderstood.
https://www.amazon.com/Michigan-Motorsports-Vehicle-1980-2016-1983-2019/dp/B0825BRP8K?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=AZ0MQOUK533GU&gQT=1
calvin
01-31-2025, 05:31 PM
Thanks. I don't think so though. It has to go from the new style 3 wire VSS that was mated to the LT4 (like the 6l90e) and back to the 2 wire for the 4l80 :(
dhutton
01-31-2025, 06:36 PM
Pretty sure I used it to convert a two wire VSS sender to connect to an ECM looking for a three wire signal. It has been a while though.
Vimes
01-31-2025, 09:48 PM
How about a 3 wire VSS for the 4L80E? The description says it's for using a 4L80E (amongst others) behind an LT1. You'll definitely want to discuss it with them before buying.
https://bp-automotive.com/product/t56-tr6060-4l60e-4l80e-digital-3-wire-vss/
ween
02-03-2025, 04:26 PM
Possibly this: https://sirhclabs.com/product/cortex-ebc-speed-sensor-adapter/
but of course not in stock. But I do have one.
calvin
02-03-2025, 04:38 PM
Thank you guys. We seem to have found a schematic and pinned a connector in there after figuring out what ground it wanted to see.
Now on to the next issue lol
