Results 1 to 3 of 3
Why wouldn't you choose larger caliper pistons?
So, I'm finally looking at bumping up from my 15" wheels to 18", which allows me to get rid of the weak and incredibly vague factory 11" discs on my 68 Cutlass. Originally, I was planning on going with KORE3's Z06 package, but it looks like those calipers are likely to interfere with any wheel I get (18x10 with 6" backspace - apparently doesn't work for Rocket Racing Attacks, and I'm not holding my breath on American Racing's VN514s). But it looks like Wilwood's AERO6 big brake setup would likely work. However, in researching this, the kit calipers come with 4.04 square inches of piston area, but they also sell, in the same physical package, 5.4 and 6.52 square inch versions.
If increased piston area gives you greater clamping force, and the factory discs for a GM A-body are massive single pistons with something like 6.7 square inches of piston area, why would you ever run the smaller piston versions of that caliper? Especially since the caliper itself is the same physical size.
