View Full Version : Ridler 652
gtome
10-14-2024, 05:10 PM
So I really like the look of these Ridler 652 and the US Wheels Bandit, but they are only 9.5" wide and 9" wide respectively. Anyone seen something super similar I could get it a wider size with an 18"? I think they would look great on my 70 Judge. My biggest draw with these is the cost. I think both are less than $300 each. I even thought about having the wheels widened. I think it's around $350 each to have them done. Still be in them for less than $700 each for the back ones. Fronts should be fine. What have you seen like these for the same sort of money?
https://www.ridlerwheel.com/652-gloss-black-diamond-face
Jk918
10-14-2024, 06:14 PM
What size tire do you plan to run or what actually fits 70 judge.
gtome
10-14-2024, 06:38 PM
That's a good question that I am not 100% certain on. I'm planning to run at least a 295 or maybe a 305, probably in a 40 series. I've heard of people running a 295 on a 9.5" wheel, but it doesn't appear to be recommended. If I can stuff a 305 in there I would like to.
I really like the look of this, but with that deep dish I'm sure that's a $1200 custom size wheel.
Edit: my mistake a custom 18x11 is $1528, not $1200.
214989
mikewoods
10-15-2024, 07:46 AM
I have 285/40/18s on a 18x9.5 with 5.5" bs the back of my 69 Tempest. I don't think a 305 would fit unless you shorten the axle and went to a custom offset wheel.
gtome
10-15-2024, 08:15 AM
I am having a custom 9" made for it, which is why I want to pick the wheels first.
dhutton
10-15-2024, 08:58 AM
Will a 305 fit without minitubs? I would have thought that would require minitubs and that usually means narrowing the frame.
gtome
10-15-2024, 12:38 PM
With my rough measurements it looks like it would without mini tubs.
gtome
10-15-2024, 02:06 PM
Dang. Only tire I see in a 305/40r18 is a Nitto 555. That's crazy!
Jk918
10-15-2024, 06:21 PM
I've seen 305 on 18x10 on the back of a few chevelle's, but those had mini tub and custom rear. I'd buy the Ridlers and have them widen for the price you noted above as I don't think anything similar will be even close to that price.
gtome
10-16-2024, 01:29 AM
Agreed. I guess I need to decide how bad I want 305's. I could probably get away with 295's on a 9.5" wheel.
dhutton
10-16-2024, 05:10 AM
That’s a lot of effort for an extra .4” of tire width.
dhutton
10-16-2024, 05:14 AM
Then again…
gtome
10-16-2024, 06:05 AM
Yes it is.
gtome
10-19-2024, 12:29 PM
I want to run a 255/40r18 in the front. Would I want an 8" with 4.5" BS or 9.5" with 5.25" BS wheel for that? That's the only 2 options I have in my wheel choice.
Jk918
10-19-2024, 06:41 PM
Although lots do it 255 on 8" its not ideal why not go with a 245 in the front. Will the 9.5 fit without frame interface
gtome
10-19-2024, 08:14 PM
I have no idea what will fit.
gtome
10-20-2024, 04:51 AM
I know guys run a 9.5 in the front, but they seem to all have more back space than 5.25".
dhutton
10-20-2024, 05:02 AM
Post number 7:
https://www.pro-touring.com/threads/130647-1970-GTO-wheel-tire-fitment
Real world experience from Andrew.
gtome
10-20-2024, 06:09 AM
Ok that's awesome! Seems like either might work. If he had 6.5" backspace on a 9.5" wheel with a 1/2" spacer (putting it at an effective 5.5"), these at 5.25" are only 1/4" difference. Although surely he's not running stock type suspension or brakes, so there will be a bit of variance.
dhutton
10-20-2024, 07:08 AM
A half inch spacer on 6.5 inch backspacing makes it 6 inch backspacing not 5.5. 5.25 is not going to cut it imo.
gtome
10-20-2024, 07:38 AM
Math is hard!
dhutton
10-20-2024, 10:28 AM
6.5 - .5 = 6 :)
gtome
10-20-2024, 11:55 AM
I'm going to take some measurements tomorrow. I have the body off the frame so can't check the fender clearance, but I can see what it looks like to the frame and suspension.
Maybe i could run those 9.5's with the 5.25" BS and use a 265/35 tire. That would be almost half an inch narrower than a 275/35.
Also my factory front inner fenders are pretty rough, so I wouldn't mind doing some modifications to them to help gain some clearance.
dhutton
10-20-2024, 03:13 PM
Fender clearance will be your issue with those wheels and backspacing. You will likely be contacting the wheel lip unless you run a lot of negative camber or your ride height is sky high.
gtome
10-20-2024, 03:52 PM
Bummer. Oh well, I guess an 8" it is. Not a huge deal really. I was just hoping to have a wider wheel so I had the option of running a 275 out front if I wanted.
gtome
10-21-2024, 03:05 PM
Put a 275/35/18 on the frame today. Just to get an idea what I was looking at. This one is a 9.5" with 6" BS.
Turns out I don't love the wheel with that much back space. From most angles you can't even tell the tire is wide. This is the car I pulled the wheel from.
215096215097
gtome
10-28-2024, 03:00 PM
Well 305's for the rear aren't looking possible either. Like I said I have the body off the frame for another week or so, so I can't get a super accurate measurement. I bent a 12" wide aluminum rod today to simulate a tire. I was hoping to run the wheel just to the bottom of the high part of the rear wheel openings. In that scenario, it looks like i would only have 2-3" of travel before it would hit. I can massage the outer wheelhouse some, but I don't know if I would get enough to make it worth it.
gtome
10-31-2024, 03:52 PM
The 305/35r20 is super tight in there. I may try to roll the lip and see what that gains me.
The first one is about where I want it for rife height, and the second is about where it hits the lip. Not more than 2" of travel there.
215184
215185
