    Results 1 to 9 of 9
      May 2020
      Vintage air vs restomod vs classic air
      Starting from scratch 68 Camaro smooth firewall nose is off the car . What’s everyone seeing is most reliable aftermarket ac out there ? vintage restomod or classic
      Mountain Springs, Texas
      The new Vintage Air Gen V is pretty nice.
      I have installed roughly 20 Vintage Air systems, never an issue.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      I've had my Classic Auto Air system on the car since ~2008. Still going strong... and that was before they have the computerized versions they have now.
      But the mechanical parts of the system have been extremely reliable.... the evaporator, condenser, expansion valve, etc... The only I thing I did different was get the kit w/o the SD5 compressor and put in a FLX7 SD7. Puts out a ~38-40F deg air out the vents on a typical high-80's, low 90's day.
      1971 Camaro
      GM HT383, MiniRam EFI, AFR heads
      "8-speed" trans (700R4 + Gear Vendors OD)
      Jun 2024
      I went vintage air and built my own controller…Name:  IMG_6189.jpg
      Sep 2009
      Atlanta,Ga.
      Quote Originally Posted by KenSacramento View Post
      Can you explain your controller more? Something like that will look good in my restomod.
      I am SUCH a rookie to Pro-Touring
      Jun 2024
      Vintage air controller is basically 3 10ohm pot’s, these days rather than using a mechanical pot I built a controller that uses a digipot and control it with a touch screen.
      - - - Updated - - -
Size:  213.7 KBName:  IMG_6193.jpg
Size:  324.6 KBName:  IMG_6201.jpg
      Sep 2009
      Atlanta,Ga.
      - - - Updated - - -
      How much do they cost to make roughly?
      Jun 2024
      I’m all in on my controller about $300 for parts, however I didn’t stop at Vintageair controller, I kept going and added Dakota digital controller, tire pressure monitor, and more, here take a look:
      https://youtube.com/shorts/VKiLXwGaL...nNiDbpDV1rnhQq
      Jun 2024
      Responce to question about cost
      Quote Originally Posted by DreKoushRanada View Post
      about 300$ parts, it was the hours of trial and error and assembly where the real cost is however, but with mine didn’t stop at Vintageair, added Dakota digital controller, tire pressure monitor and more, take a look.
