View Full Version : Transmission / Torque Converter Noise
skooli
08-23-2024, 10:42 AM
Anytime my car goes into gear I hear a chattering noise. It doesn't make the noise at idle, and it increases with rpm, then goes away around 2500. I've been told it sounds like a loose torque converter so I got underneath and checked the torque converter bolts. They were all tight. Anyone have any idea what it could be?
https://www.youtube.com/shorts/qhgtorHUG7Y
Wardawg1
08-23-2024, 06:22 PM
Could be a cracked flex-plate making noise. Cracks around the bolts to the crankshaft
dontlifttoshift
08-24-2024, 04:40 AM
Any evidence of rubbing when you had the dust cover off?
Alaska442
11-12-2025, 09:31 AM
Mine did that, was a Turbo 400 and turned out to be a broken stall converter. I waited too long to drop the trans and it wound up going through a lock up on the way home.
