    Results 1 to 6 of 6
      Sep 2007
      Front tires hitting fender
      Hello guys, it’s been awhile since I have posted. Life just never seems to slow down. A problem arose that I was not expecting. My front tires use to rub when traveling over big bumps. After dealing with this for years and finally realizing a new front set up is not going to financially happen I decided to at least install taller upper ball joints. The rubbing is now worse. The tire hits between the 1-2 o’clock position on the passenger side and 10-11 o’clock position on the drivers side. Is it possible that the taller ball joints put the spindle is a worse position in the camber curve?(which I didn’t think is possible). The following is my setup:
      67 Camaro, big block springs, 2” drop spindles, disc brakes, 17x7 wheel w/ 3-3/4BS, 225/ 50 tire.
      Apr 2018
      Oakland
      How old are the body bushings? Maybe you have a shot one now, therefore lowering the body.
      Check your body bushings, check your frame alignment, and then check your front end alignment. Especially since it's rubbing in different spots.
      Nov 2018
      A taller upper ball joint can shift the position of the wheel just a bit, and it sounds like it shifted your wheel position forward a bit. Don't suppose you have some side-on pictures you can compare wheel position with, do you?
      Your inner wheel wells have some interesting bends inside, so once you check the condition of your mounts I would go find the shiny spots in the wheel well and give them a little BFH massage. Go a little at a time, and spray with paint after so you can find the rubbing spots again if you didn't smack it around enough. Or if they're plastic, a little heat gun action will get you through. You'll want something rather large and metal to gently press into the plastic to help push it into its new position. Oh, and make sure you know what's on the other side of the wheelwell so as to not damage anything else.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Mountain Springs, Texas
      Those wheels are about an half inch short on backspacing. Did you get a front end alignment? You will need negative camber, -.5 degrees would be a good target and should improve the rubbing issue. Shoot for 3 to 4 degrees caster if you can get it.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2007
      All body bushings are good.
      @Don, I have not performed a wheel alignment yet, but that was what I was thinking of doing next.
      Thanks.
