View Full Version : Formula 43 wheel help
Bertojr29
01-16-2024, 09:00 PM
I bought a set of formula 43 rad10 wheels. I know they are no longer around. But what i need. Is the tourque specs for the 30 bolts that hold the 3 piece wheels together. I知 gonna be refinishing them so they have to come apart. If anyone can help me I would appreciate it thanks
dontlifttoshift
01-17-2024, 05:32 AM
What size is the hardware?
Bertojr29
01-18-2024, 08:27 PM
I値l check tomorrow and get back to you what size they are
carbuff
01-19-2024, 12:21 PM
I would expect you could use the same torque specs I used on my Forgelines, as I'll assume the hardware is going to be the same size. I was told to use 26 ft-lb for any bolt/nut fasteners and 25 ft-lb for any blind bolts (which is what it appears your wheels use). I was also told that I could use anti-seize on the bolts (although I didn't), but not to use Loctite.
dontlifttoshift
01-22-2024, 05:25 AM
And that is probably correct but I wasn't sure what size the hardware is.
Bertojr29
01-22-2024, 04:45 PM
Here痴 a pic of the bolts that I知 talking about Thanks for the help
dontlifttoshift
01-23-2024, 05:47 AM
For those of us that went to the moon, that's 1/4" if you torque that to 25 ftlbs you will have a bad time.
12 ft lbs if they are grade 8 or better.
