    Results 1 to 3 of 3
      Eastern Virginia
      Corvette C5/C6 rear bearing hub without snesor?
      Is there a bearing hub assembly that will work on a Corvette C5/C6 that does not have the sensor in it?
      Scot
      86 Monte SS
      Nov 2016
      I would love to know myself as well. Please post a response if you find out. I'm working on a project that doesn't need the sensors and I don't want the little sensor pigtails hanging out.
      Mar 2015
      Quote Originally Posted by Samckitt View Post
      The C7 rear hub does not have a pigtail, same pattern for the hub mounting flange and same wheel lug bolt pattern, it does has a 33 spline so similar to the Z06 and ZR1 C6 hubs, your base C6 hub used a 30 spline
