View Full Version : 3D printing dash bezel
Cheveezy
12-29-2023, 07:24 PM
Anyone know of a company that has a 3D printer big enough to make a custom dash bezel for my 65 Chevelle? I'm looking to keep the gauges set up like stock but eliminate the radio and A/C vent. Not a fan of the radio delete plates I've seen. Something like the attached picture, except not billet aluminum and not $4500 lol.211136
andrewb70
12-31-2023, 07:08 PM
I have been working with Reversion Raceworks for some parts on my GTO:
https://reversionraceworks.com/
Usually what is done with large parts is that they are printed in pieces and bonded together into the final part.
Cheveezy
01-01-2024, 07:23 AM
Awesome! Thank you Andrew!
btmatt
01-02-2024, 07:53 AM
check Sew It Seams Custom Upholstery in New Braunfels TX. I toured the shop and they have a scanner and several printers and were working on custom parts for an F100 SEMA build.
They will do a custom interior for my '57 custom truck in the near future
Tsaints1115
01-02-2024, 05:38 PM
https://classicdash.com/?make=131&model=157&year_id=207&post_type=product&action=vpf-search
Cheveezy
01-02-2024, 07:57 PM
Thank you!
- - - Updated - - -
Thanks, that's an option if I can't get exactly what I want.
thedugan
01-03-2024, 04:24 AM
Classic Dash has a page for blank dash panels. If they have one for your 65 you can cut the holes yourself and get the layout that you prefer.
TheBandit
01-03-2024, 03:03 PM
I used D3D printing services in Tujunga CA to print my gauge cluster insert out of ABS. Mine measures about 18" wide and was printed with the front curved face down on the bed. I designed this myself. Looking at the size of yours, you may be better off using two pieces and joined by pinning and gluing, then hide the seam with body filler and sanding.
211261
Here you can see the layer lines before filler and sanding. They are a bit exaggerated because the face is curved. If yours is flat, the layer lines will not be nearly as noticeable or take as long to sand smooth.
211262
I used several coats of Bondo sprayable filler primer with hand sanding in between by an assortment of sanding sticks (made by gluing sandpaper to popsicle sticks) and sponges to clean up the layer lines. This took quite a bit of work and you might consider using vapor smoothing or another method of filling if you want things to be smooth.
211264
I finished my insert using SEM black interior dye spray (which I also used on the original dash piece) and Molotov chrome pen with a Alclad Aqua Gloss sealer for the 'chrome" edging.
211263
Getting the design right took a lot of time in CAD and I printed 2D templates from my CAD model to check fitment before I finally sent it for printing. It's not perfect but it's unique and was a really rewarding project. I hope you have a good experience!
Cheveezy
01-03-2024, 04:51 PM
211261
211262
211264
211263
That came out great! Appreciate the detailed response!
- - - Updated - - -
Thanks, last I checked with them they no longer offer the blank for a 65.
- - - Updated - - -
Great, thanks. I'll check them out.
dburro8
12-28-2025, 12:42 PM
I would love to get that file to 3d print one for my ventura if you would be willing to share it thanks
JustJohn
12-29-2025, 04:56 AM
Trimech Solutions is our CAD vendor but they also sell 3D printers and print to order. You may have a local office near you.
Drakos911
04-03-2026, 09:33 PM
Hi Cheveezy who makes this $4500 billet aluminum dash bezel you posted back in Dec 2023? Could you please let me know the vendor? Thanks.
Cheveezy
04-04-2026, 06:47 AM
Michigan Machine Worx was the vendor.
