    Results 1 to 6 of 6
      Nov 2023
      wheel tire limitation from shock mounts on a 1967 camaro ridetech suspension system
      I am running into the shock mount limiting the rim width to 10 - 10.5" I could easily fit 11.5 if the ridetech 4 link shock mount was not so far in the wheel well.
      Has anyone put 24 inch rim on and let the mount ride in the barrel of the wheel?
      What is the largest set up you guys made work?
      Thinking 305/25/22 with a 10 or 10.5 rim with 53mm backspacing (4 inches)
      Mountain Springs, Texas
      22 or 24 on a first gen is pretty much unheard of here…. Most run 18 or 19….
      10 is pretty much max width on a first gen without minitubs unless the ride height is quite high…
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2010
      Beach Park IL
      Grab a tape measure. What is the measurement from the center of one lower shock mount to the other?
      Donny
      Quote Originally Posted by grverner View Post
      When you say 10-10.5” wheel are you including one inch for the lips? For example a 10 inch wheel measures 11” wide….
      275 tire is also pretty much max for a first gen unless the ride height is quite high….
      Don
      Lawrenceburg, TN
      Pictures?
      Lawrenceburg, TN
      there is a bunch of room for the wheels unless you narrowed the rear end to far
