Results 1 to 10 of 10
09-05-2023 #1
- Join Date
- Sep 2023
- Posts
- 6
'70 cuda, anyone have an offset upper 3rd link?
I'm far from done (see photo), but headed along the lines of Hot Rod Garage drift Cuda, except will install the upper 3rd link offset 6" to the passenger side. The chassis end will end up inside next to the driveshaft tunnel, so looking for lessons learned fabbing up mounts and a cover.
It won't have a rear seat, and it won't need a roll cage. The stroker 383 (496ci) is still in the machine shop, I don't expect it to have more than 600fwhp or get into the 10's, plus the nearest drag strip is too far. Might install a 6pt roll bar. It's not a daily driver. It's a play car, was 2bbl/383 Gran Coupe.
Also plan to use the QuickCar torque absorber. Lower links will be 28" long, upper will be 20". No I won't be using the air bags or helix parts in the photo.
