    Results 1 to 3 of 3
      Miami
      Drop spindle suggestions please
      Hi I'm running Hotchkis upper and lower control arms. Anyone know what a good dropped spindle is? Wanted to run ridetech truturn but wasn't able to get a straight answer on if this works with these control arms. Any help appreciated. Thanks
      Sep 2004
      Santa Barbara, Ca
      I’m not all that familiar with the Hotchkiss arms, but I’d think you’d be fine using the ridetech tall spindles as long as the control arms use a standard height ball joint.
      I’m using the ridetech lower arm and TruTurn package with a Global West upper arm. Most of these upper arms have extra caster built into them, but I think that’s about it. You probably won’t get a straight answer from the manufacturer on this, as they likely haven’t tested these different combinations and they’d prefer you to buy their control arm setup.
      My thoughts anyway.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      Apr 2016
      ridetech has a new corvette hub spindle you can also run the tru turn on. I've seen quite a few different arms with the tru turn package pretty confident you'd likely be able to. Could reach out to Suspension Geek, I'd bet he'd have a answer for you.
