Results 1 to 6 of 6
Thread: 88-98 LS rear disc swap
07-28-2023 #1
- Join Date
- Feb 2005
- Posts
- 201
Hey Guys,
I just purchased a 95 GMC Sierra has anyone been able to install rear LS brakes on this trucks 10 bolt?
I have a spare rear disc brake set I would like to eventually install
Vince
07-28-2023 #2
- Join Date
- Aug 2007
- Posts
- 738
So if you have the calipers and brackets it should be easy to mock and see what mods are needed.
You have to pull the rear drums and reinstall the axles to do some measuring. Do your calipers have the e-brake in the caliper or is it like a little drum brake in the disc hub?
I've used the 97 Camaro rear calipers/rotors and older on 2 gen Camaro 10 bolts. They worked well. I've also used the 98 Camaro and up. Again they worked well.
07-30-2023 #3
- Join Date
- Feb 2005
- Posts
- 201
The parking brake is in the hub, like the drum brake in the set I have
07-31-2023 #4
