View Full Version : Name this sound
jn66
07-11-2023, 02:46 PM
Hey Fellas -
Just took a quick video. The 'scratchy' or 'grumbling noise' is this normal? I can hear it in the video. Hope it comes through OK. It is like 'breath, scratch, scratch - breath, scratch, scratch'
https://drive.google.com/file/d/108ohsmenmex-An_G6uZP6LSKV0c1Rhbe/view?usp=sharing
Engine:
468 blown big block 1098 Hp
Crowler crank
World block and heads
Edelbrock aluminum water pump
Lunati rods n valves
671 Weiand blower
2 x Holley carbs 4150 hp race series
Also, if this is posted in the wrong area, please move.
Thanks in advance!
Larry Callahan
07-11-2023, 03:43 PM
Hmmm.. Blower bearing?
So, no real clue.
Hotwire
07-12-2023, 03:41 AM
Have you checked the oil level in the blower?
https://youtu.be/p-wMTv6XwRg
jn66
07-12-2023, 06:53 AM
I have not Sir.
I’ll do that.
Thank you.
jn66
07-12-2023, 08:34 AM
Found some oil leaking here as well. Might need new seals.
208272
ZZ430
07-12-2023, 08:37 AM
Yeah, check that oil level!
Even with no visible leaks. Maintenance should be done at regular intervals.
208273
Edit: I just now saw your above photo. I use a gasket not silicone.
And this kit: https://theblowershop.com/product/front-bearing-and-seal-kit-1152/
jn66
07-12-2023, 08:44 AM
208273
Thank you.
This is new to me. First time I've had an engine with a blower on it. I don't notice any easy way to drain/fill/change the oil haha. Might have to take it in. Engine was assembled in 2012/14. I don't think much maintenance has been done since then at all. Not a whole lot of miles were put on it.
Hotwire
07-13-2023, 04:19 AM
Thank you.
Watch the video I posted, they give you tips on how to maintenance the blower. :twothumbs
jn66
07-13-2023, 06:06 AM
100%. I did watch it. Much appreciated Sir!
