    Results 1 to 2 of 2
      Canada
      anyone have a proven M/C combo for Baer brks?
      I have a 71 chevelle with 13" 2 piston Baer track kit and the 12" single piston kit in the rear. I need to use a manual m/c setup because I think the hydraboost is too cluttered looking and I have legs strong enough to bend the firewall from spending more time at the gym than at work. So i'm not concerned with pedal effort within normal human limits. There is a lot of info on master cyl's but nothing on this exact system. I'd like to know if anyone has this identical setup and what master they used and which position in the pedal they put the rod etc.
      Chicago
      Cluttered looking, last time I checked, it is 1/2 the size of my old power setup. It works 1000 times better than any power disc system.
      IF you are looking at a manual braking system, your legs better be strong. You will be on that bad a$$ and the car will probably still roll.
      Maybe you want to look into an electric system from mp brakes. I still say throw a hydroboost in there. You will not get better than that!
      Semper Fi
