View Full Version : Transmission cooling lines hard/braided
68400BIRD
03-29-2023, 09:16 AM
Hello, I am installing a 200R4 into my 1968 Firebird. I am getting close to the cooling lines and adding a transmission cooler. I would prefer to not run the cooling through the radiator.
The transmission that I removed was a turbo 400. The stainless cooling lines are still in the car and might be able to make them work but I think it would be difficult to get them to fit correctly. Since I want to run a separate cooler the lines do not really end in a very good spot. One is high and the other is low from the original locations on the radiator. Just wanted to get an idea of what other people have run for lines. I see a couple of kits where you get two braided lines to run from the transmission to the new cooler. Is this my best option??
79 Camaro
03-29-2023, 01:02 PM
On my LS/4L60E swaps I run -6 SS lines. Easy to route. I buy bulk -6 lines and fitting as needed. Lots of rubber lined clamps to keep the hose secure. If you are buying a new external trans cooler get one with NPT inlet/outlet so you can use -6 adapters. Couple of pics.206630206629
ZZ430
03-29-2023, 06:37 PM
69 Camaro, 7004R Aeroquip -6 AN and fittings.
206635
Then trough a remote filter into a BeCool radiator. Could just as easily go to external cooler, but this works well. Using a trans temp gauge and it's always within limits.
206636
Pro Touring Store
03-29-2023, 06:55 PM
You can easily run rubber or AN hose to and from.
I've also made hard lines around the oil pan and/or crossmembers and used compression type AN fitting adapters to connect the front and back. Especially if it could get close to say, the flexplate, starter, exhaust, etc.
-Dale
Lonnies Performance
03-29-2023, 07:12 PM
Look into stainless braided Teflon lines. They last much longer than rubber & are also thinner in diameter for easier routing.
68400BIRD
03-31-2023, 05:34 AM
Thank you for the suggestions. Looks like I will be running braided lines to a cooler that has AN fittings. I really wanted to stay away from hose clamps.
79 Camaro
03-31-2023, 12:43 PM
Just a note I do find the teflon lined -6 hose is easier to assemble compared to the rubber lined -6 hose. The teflon lined -6 hose and fittings are a bit more expensive.
