    Results 1 to 7 of 7
      Missouri
      If you have or want a Lateral Dynamics subframe, you may want to read this!
      I purchased mine last year in Feb, it was delivered in June. It was the 5th one built. I was told it would be a 6-8 week build, none the less I did get it and all the parts. I've experienced a number of issues.
      First was the engine mounts didn't line up. Easy enough to deal with. Then there was the fact that the body mounts didn't line up, they were off an inch rearward. I hogged the mount out and was able to line it up to were it didn't bother me visually. The transmission crossmember mounting holes didn't line up with the subframe. And the big one was and the one that just happened was the upper control arm mount bent and then failed. In my opinion the mount bent because of the upper shock mount bending the plate into the cross shaft of the control arm, which then increased the leverage on the thin portion of the shock mount and it broke. The passenger side was worse than the drivers side. I suspect that my car was the first one on the road with this subframe.
      The motor mounts.
      Name:  Engine Mount2.jpg
Size:  340.3 KBName:  Engine Mount1.jpg
      The body mounts
      Name:  Body Mount 1.jpg
Size:  218.8 KBName:  Body Mount 2.jpg
Size:  268.6 KBName:  body mount 3.jpg
Size:  277.3 KBName:  Body mount 4.jpg
Size:  371.2 KBName:  Wheel Opening1.jpg
Size:  253.7 KBName:  Wheel Opening2.jpg
      Transmission Crossmember
Size:  358.0 KBName:  Crossmember 2.jpg
      The mount failure
Size:  360.2 KBName:  Failure_1.jpg
Size:  292.4 KBName:  Failure_3.jpg
      Sean James
      69 Firebird - Build Thread
      72 Firebird
      Mountain Springs, Texas
      Hopefully Mark is going to make it right.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      TuoCo, CA
      Do you talk to LD before you started making these mods? Curious their take on this.
      Steve
      '68 Camaro - SBC, TKO600, 3.73 Moser 12-bolt, Speedtech, ATS-AFX, Hotchkis, Forgeline, Ron Davis and C5 brakes (Kore3), Holley Terminator TBI.
      Check it Out Here
      Missouri
      Quote Originally Posted by eville View Post
      Yes, I have been in contact with him up until this last issue and have gotten no response as of yet on that but here are the responses to the others.
      LD response to the body mounts was "At first thought, no, I can't think of why it would be an inch off. When you say that there isn't room to move the sub forward an inch, do you mean because of the body bushings, or? In other words, what is limiting the movement of the frame relative to the body? Sean, I have to admit I can't provide an answer. I see the interference clearly in the pictures. It looks like both pictures are of the rear mounts, correct? Do you have any clearance issues with the mid-body bushings as well? I don't have my frame mocked up in my car but will in a few days to see if I can see the same thing. It looks like you have the Global West interlocking style body bushings? I have never worked on a Firebird, but I have NEVER heard of any differences that could account for that so we should assume it is not the car body."
      I replied with "The black bushing is the rear and the blue is the mid and yes they are global west. I elongated the mounting holes and moved it until the mid bushing was against the box. Still not 108” but 107.75”. Actually the Firebird wheel base is 108.1” and the Camaro is an even 108”. Go figure. The wheel is centered visually and I’m okay with that. "
      LD Response "Okay got it. That was exactly what I was going to suggest to deal with the situation, so great recovery, great job. I am truly sorry, I will get to the bottom of it. "
      I never heard anything else from him on it.
      LD Response to the Engine Mounts "Thanks for the note, I will make a change to the engine mount tube going forward as it looks like i am off by 1/8""
      LD response to the crossmember "I am scratching my head for the small but important differences you are seeing relative to the frame I have at my place for my car. I made them at the same time, four crossmembers too and checked them all out. I am really sorry for the inconvenience."
      Sean James
      72 Firebird
      I saw on Instagram he was moving to San Diego in February. Not sure if he was going to continue with Lateral Dynamics or not. Nothing posted since then.
      Don
      Sep 2004
      Santa Barbara, Ca
      Ouch. I had a similar issue with UCA mounts breaking on an old Wayne Due C5 subframe. After that, I had an Art Morrison C6 subframe that I suspect was on its way to breaking in the same place. I sold that car, so never found out if it had a problem, but the powder coat was chipping off at the weld. Not a good sign.
      If I ever do another aftermarket subframe, I think I’ll be going with DSE. Seems like their engineering and build quality are well sorted.
      Andy
      1967 Camaro RS
      Magnacharged LS1/T56
      543 rwhp, 516 rwtq
      Sold
      1968 Firebird
      LS427/570 and T56 Magnum
      Missouri
      Either Detroit speed or Speedtech would be great options. I know a few guys with each that race and none have had issue to my knowledge.
      Sean James
      72 Firebird
