    Results 1 to 2 of 2
      Mar 2013
      Sunny Calif
      F Body LOW MOUNT HOLLEY A/C BRACKET and SWAY BAR CLEARANCE?
      LOW MOUNT HOLLEY SD7 A/C BRACKET for LS swap.
      Has any one installed this mount in notched crossmember 68 Camaro.
      Does the A/C idler/Bracket clear the sway bar?
      More so a larger aftermarket Detroit Speed Sway bar?
      Called Holley, tech response was vague, " I don't see anything noted in system that states sway bar interference in that application"
      Mar 2013
      Sunny Calif
      Ended up having Innovatrix Suspensions bend me up a custom sway bar to clear low mount compressor that sits in original LS rear balancer pulley location. Fit like a glove they dropped center section and moved the turned up ends nearest frame bar mounts.
Size:  25.3 KBName:  schem2.png
