View Full Version : 1970 OO Judge
gtome
02-23-2023, 07:31 PM
Hey guys. I sold my Hurst Rambler today so I figured it would be a good time to start building the Judge. I plan to keep the body fairly stock since it is a real Orbit 70 Judge. I'd like to add coil overs , probably something like an LQ9 and a TKX. I like the look of stock style Rally 2 wheels and found a couple options. Unfortunately they don't come in anything over a 9.5" wide. I was thinking maybe 18" front and 20" rear. I'd love to stuff a 305 in the rear, but it won't happen on a 9.5" wheel, so unless I go for another style, a 295 is probably a big as I can go. I have to restore the car too but I'm hoping it won't take too long. Any recommendations on coil over kits? I'm trying not to break the bank on this one and will not be doing any sort of racing, I just want a good tight ride and I like the height adjustability of the coil overs. And if anyone has seen a nice reasonably priced wheel that might look good I'm open to others. I found a 295/30/20 at work and there is plenty of room. US Mag or Rev 9 is what I was looking at for wheels.
https://www.performanceplustire.com/app/buy-wheels-online/rev-wheels/109-classic-magnum-polished/ws:20x9-5
205827205826
FORDvsCHEVY
02-24-2023, 01:46 AM
I had a 295/30/20 in 10” wide wheels and the were very squared…. No stretch at all. I think it might be 2 wide for a 9.5
gtome
02-24-2023, 04:48 AM
I believe I saw they recommend a 285 max on a 9.5 wheel. I saw a video of a guy that had a 285, 295, and a 305 on a 9.5" wheel. The 285 and 295 looked fine, but the 305 looked weird. I suppose it also matters what tires they are. Surely they are not all the same. I am not married to those wheels, it's just a good looking affordable option. I even considered seeing about having them widened. They do make those in bigger sizes, but they are a 3 piece. $300each for the ones I'm looking at or $1700 each for the 3 piece. Big jump $$!
thedugan
02-24-2023, 08:13 AM
Nice project.
You could have the wheels widened. One example of a company that does it. https://weldcraftwheels.com/
gtome
02-24-2023, 11:22 AM
Yeah I looked into that. It's about $300 per wheel and they will only do the backside on those. That would end up having way too much backspacing (about 6.5") for a wide wheel for me. I'm in a situation for sure!
gtome
02-24-2023, 01:34 PM
Anyone have any thoughts on a reasonable coil over kit? And are tubular A arms necessary?
Way2qwk4u
02-24-2023, 04:35 PM
Umi performance suspension. I have really enjoyed mine over the last 10 years.
gtome
02-25-2023, 04:32 AM
Nice, I've been looking at a bunch of them. Seems like they are all pretty similar except for the shocks.
gtome
02-25-2023, 04:34 AM
I want to try to get my wheels picked out and in my hand soon, because I have to put outer wheelhouses in it, and I could modify them a bit if needed to clear a wider tire.
Up front (if I go with the wheel I linked) I would probably go with an 18x9 with maybe a 255/30 or 35.
andrewb70
02-25-2023, 06:10 AM
In my opinion, 18" wheels on the front and 20" wheels on the rear make these cars look very awkward. I would do 18s or 19s all the way around.
thumper877
02-25-2023, 07:56 AM
To each his own but I agree with Andrew I think it throws the appearance of the car off
gtome
02-25-2023, 03:56 PM
Ok. I will look at that option. The wheels I'm looking at don't come in 19's. Might be time to look at other options. Getting to be too many strikes against them.
gtome
02-25-2023, 04:00 PM
Also I'm open to suggestions. Seen anything recently that looks good on a gto? Trying to stay under 2k for wheels.
gtome
05-20-2023, 01:10 PM
Ok. I finally got the outer wheelhouses and quarters finished up. I've been looking at different options for the drivetrain. I had talked myself into a LT1 and a 10 speed, but last night a deal fell into my lap on a 2012 Corvette. Obviously I can't use the trans so I'd have to get that figured out. Probably go with a TKX. Does anyone know if I could make the Corvette brakes work on my car? I see some F and G body conversions, but I don't see anything for an A body.
andrewb70
05-22-2023, 06:48 PM
Kore3 has brackets if you want to use stock spindles. A better option is to get the SpeedTech spindles and the appropriate control arms. Their spindles use modern C5/6 hubs and use the Corvette brakes as well.
Jk918
05-23-2023, 03:12 AM
Ridetech offers a kit for the A body that comes with corvette hub spindles(looks to be new designed spindles by Ridetech), not sure if it's compatible with the tru turn drive link. Might be a good option as your trying to run some larger front tires.
gtome
05-23-2023, 04:06 AM
Thanks guys I will look into those. Just want to try and use as much of this car as possible to make buying it worthwhile.
This is a real orbit orange Judge so I also have to be careful I don't do anything I can't undo if I wanted/needed to.
Joris69velle
05-23-2023, 07:13 AM
There is a template on the internet but now i cant find it. I used in on my chevelle. If you have access to a laser cutter. It also requires a small bushing and you need drum brake hubs. Ill dig for some pictures if i still have them
Joris69velle
05-23-2023, 07:16 AM
207577
You can also machine down ur old discs brakes to hubs. Press in bigger studs and use the corvette rotors
gtome
05-23-2023, 03:51 PM
Interesting! We do have a small machine shop at work. I bet my guy could machine them for me.
I'm not 100% sure what I'm doing for a rear end yet. I have a couple of 10 bolt rears but I'm not sure what kind of power they will hold. I will be running the LS3 with something like a stage 2 or 3 cam in it most likely(so less than 550 crank hp). I've kicked around putting a turbo on it, but I have some much work to do on the car still I doubt that would ever happen.
GTO Jack
05-24-2023, 06:13 PM
I had 295/40/20 on 10" rims on my last Hellcat and still had a bit of bulge. On this one, I used 10.5" rims and same tire and they have perfect flat sides. If you go that route and need a pic let me know. I'm working on a 65 GTO and looking at rims and tires. I may do the 17" Rally 2 wheel running the 9" on front and have the back of the other 2 widened to 11". If you widen the tubs you need more back space anyway, if I can find tires that fill the wheelwell.
gtome
05-27-2023, 04:27 PM
Yeah I am still unsure on the wheels and tires. I really wanted a rally 2 style wheel, but the ones with good sizes are just way out of my budget.
Also if you decide to go with the 17" Rally 2, hit me up, I think my buddy is going to sell the ones he bought in favor of something else. They are new but have been rolled around the garage a few times on them. I have a nice original 4 speed console too for a 65. I sold my 65 but still have a few nice parts.
gtome
05-28-2023, 05:05 AM
I also looked long and hard at the wheel tubs on mine. I'd love to run a super fat tire in the back, but I just can't bring myself to cut up a real Judge for that. I considered selling the judge and using something else like a regular GTO or Lemans to build. Offered it up to a couple people I thought might be interested, but they just weren't willing to pay what I think it's worth. I've also had the car since like 1984, so it is a car I've been thinking about for 38 years.
gtome
06-04-2023, 04:24 PM
Ok. I almost finished the outer wheelhouse and partial quarter panel replacement. Time to start moving forward. As I mentioned earlier, I picked up a 2012 Corvette with an LS3. I've been looking at motor mounts and swap kits. Anyone have any recommendations? Some of these (for example Sikky) can be pretty pricey. Others, like a Hooker headers kit, are not too bad priced. Anything special I should be looking out for or to be careful of? I'm still not 100% sure on the trans yet, but it's looking like a TKX is at the top of the list. I super don't want to modify the tunnel, but unless I run an old 4 speed I'm not sure I can avoid it.
207809
Jk918
06-05-2023, 06:05 PM
Holley clamshell motor mounts and transmission crossmember, speed engineering headers
gtome
06-06-2023, 09:46 AM
Thanks I will take a look.
gtome
07-16-2023, 01:17 PM
Does anyone know if I will be able to use the oil pan that is on the LS3 I bought, in my 70 GTO? I don't have the engine out of the Corvette yet so I don't know what all I will need. It's a 2012 Vette if it makes a difference.
