    Results 1 to 7 of 7
      May 2015
      Morris 3 point seat belts
      Does anyone know if the Morris 3 point seat belts will work with 2000-2002 Trans am seats in a 68 camaro? I just swapped out the bmw seats for some trans am seats and now need some seatbelts.
      Jan 2011
      Charlotte, NC Region
      I have a set of 2000 TA seats in a 69 Firebird. The Morris 3 points work perfectly.
      Our seat belts will fit with those seats.If needed we have extension brackets that move the seat bel reel rearward 6.5" and 9.5".Check out our Clear Shot door mirrors that Eliminate the passenger side blind spot and stay adjusted.
      Billy
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by robbbc View Post
      i use them with 4th gen camaro seats in my 67. works quite fine, but the belt isn't going through the seat belt guide.
      Would buy again!
      Scott from NJ.
      Vent Windows Forever! ...
      May 2015
      Thanks for the responses guys. I'll take a little closer look at them since I shouldn't have any issues of them fitting.
      May 2015
      Quote Originally Posted by morrisclassic View Post
      Billy
      Thanks for the info Billy. I appreciate you mentioning the mirrors as well. They sound like something id be interested in, just not at the moment.
      May 2015
      Are the MCB front seatbelts for the 67 different than 68? If so, i have found some cheaper on ebay than what i was quoted when i called to place my order. I called and was quoted $355 for the fronts. Mentioned I was a member on this forum and was gave a slight discount. Was appreciative of that but once i looked on ebay, i found they were priced $20 cheaper. Clicked the ad and there was a code for the same % discount i was quoted. Just an fyi for anyone out there looking...
      They are indeed listed for 67-69 so should work.
