Results 1 to 10 of 10
12-23-2022 #1
- Join Date
- Dec 2007
- Posts
- 14
A-body reduced scrub radius options?
I'm working on getting my dormant '66 GTO back on the road and one thing I want to address is the lousy front suspension, which is currently stock save for stiffer springs and a TA sway.
I know the standard formulas that are now tried and true. Tall ball joints on the stock spindles with new upper a-arms. Or AFX spindles and whatnot.
But none of these options addresses what I see as a significant failing of the suspension, which is that it has a ton of scrub radius. I think it's like 2.5"? I used to wonder why, when I would turn the wheels, I always had to worry about the tire contacting the very bottom point of the wheel cutouts in the fenders and now I understand that it's because the massive scrub radius swings that wheel around like a sack of potatoes. And it also makes the steering stupidly heavy.
So.. are there any solutions to this floating around out there? It seems that the basic solution is slightly longer a-arms at top and bottom coupled with greater negative offset wheels. Like a C4 Corvette, for instance. It seems this would be a wonderful improvement to the system, now that the basic geometry has been ironed out by the aftermarket.
