View Full Version : pro touring 65 vette starter
Knifeman1
11-12-2022, 05:44 PM
I came across this 65 vette, looks like it could be a good project starter. Im no corvette expert but from what i can tell it was an original 350 car. The owner says it was modified back in the 90s before they bought it, ( flares, hood, pipes, interior) It looks solid just a couple small spots in the fiberglass need repair. Im not sure what the value is in this bad of shape. There is no engine in the car and the original engine is gone.203432203433203434203435
79 Camaro
11-13-2022, 01:58 PM
The flares can be fixed. But the wind shield rust (bird cage per the Corvette guys) can be a killer. Also frame rust. If its been sitting on damp ground for awhile it's not going to be pretty.
The good? It looks like it has all the window trim. Doesn't look like the front end has been modded but no bumpers?
I assume the radiator support is still in the car? If it's rusted out on the bottom you will have rust other places.
In 65 there wasn't a 350 only 327.
I wouldn't touch it if I couldn't get it up in the air and get a good look underneath.
Knifeman1
11-13-2022, 04:17 PM
Thank you!
What is a good way to check the bird cage without taking the car apart? They say the car was covered outside but hasnt been registered since 2017. so I assume its been sitting for 4 to 5 years.
79 Camaro
11-13-2022, 05:11 PM
I would go over to corvetteforums.com and ask the same questions.
jimco84x
11-14-2022, 09:45 AM
Thank you!
Look closely around the windshield frame and around the dash. There is metal there that will rust. If the trim is removed, it will be much easier to spot.
If the interior is accessible, the passenger side kick panel can be removed with a phillips screwdriver easily. If it's still clean and green from the original primer, you're probably in good shape. This area gets wet and builds rust and scale.
Check the frame at the body mounts and in the area just behind the seat where the frame kicks up. They are bad about rusting in that area. A new frame is bad enough, but rebuilding the birdcage is tough.
Agreed that I wouldn't consider an offer on it until I could get underneath it and do a little poking around. If the seller refuses, walk away.
chevelletiger
11-16-2022, 11:41 AM
What are they asking for it? If it's too big of a project I'd take it on as my wife wants a 63 split,but this is as close as.shell get $$$ wise
Knifeman1
11-16-2022, 03:59 PM
they are trying to come up with a price, In the shape its in with the engine missing and body modifications I thought it would make a good pro touring build project.
Vimes
11-16-2022, 08:30 PM
If this doesn't work out, how "63 Vette" does it have to be for your wife?
https://www.crcoachworks.com/models
These guys sell rebody kits for newer Corvettes that have the older Corvette look. They aren't the same as they have to conform somewhat to the newer car and it'll be an obvious rebody kit, but they do a pretty good job of integrating the older design queues to the newer body. I've always liked them, but never used them.
ragtop1968rs
11-21-2022, 12:46 PM
Did you find out anymore about this? I'd be interested if you pass on it. What state is it in?
Bulletpruf
11-21-2022, 05:42 PM
Sweet project! Let us know if you end up with it!
ragtop1968rs
11-30-2022, 06:26 AM
Did you get the car?
Knifeman1
12-17-2022, 02:12 PM
I got it yesterday and got it home. I have some better pictures now i will post.
aaroncorvette
12-18-2022, 05:33 AM
I look forward to seeing pics and hearing about the vette. I've got a modded '71. like others have said Vette's don't like sitting outside, they rot big time. Hopefully you didn't pay too much for it? Although it's a great project to Pro Tour. Good luck!
Knifeman1
12-18-2022, 11:37 AM
204190204191204192204193
';dlkfjngg;azlkjdfsg;alierjgf;oairejgfa;oirjvb;oai dfjvo;izdfjv;oizdfjv
79 Camaro
12-18-2022, 02:35 PM
I know its way early but over on Corvetteforums.com there is a guy that makes a really slick electric head light motor conversion. I used it on my 71 C3 and it allowed me to get rid of all the vacuum stuff. Worked great.
Good luck with your project.
Knifeman1
12-19-2022, 04:56 AM
Thank you! Ive got to start doing my research and figure out what parts to go with. I think im going toward a weekend warrior auto cross pro touring build. detroit speed underneath, maybe new chassis or maybe stay with the original.
Alwhite00
12-21-2022, 07:36 AM
Good looking project.
Knifeman1
01-10-2023, 04:25 PM
Thinking of selling this one if you know anyone looking for one
ragtop1968rs
01-13-2023, 03:51 AM
Is the frame and birdcage solid? Where is it located? Can you pm me a price. Or text me at 616-406-6385. Thanks
ryeguy2006a
01-13-2023, 06:30 AM
Just throw a motor and transmission in it and drive it!
tyoneal1
01-13-2023, 10:00 AM
Please text me a price 2143947364.
And any more information you have on it.
Hopperj7
02-11-2023, 02:27 PM
Did you end up selling it? I would be interested in it as well. What state are you in?
1968driver
09-08-2023, 12:44 PM
what ever happened to this 1965 corvette? Curious to find out.
ragtop1968rs
09-12-2023, 03:59 AM
I bought the car from him back in January.
MachineADDICT
01-24-2024, 11:44 AM
Where’s this beautiful beast at right now? Lucky guy whoever’s got it!
ragtop1968rs
02-01-2024, 06:07 AM
This is what that car looks like now. I got rid of the nasty flares. It’s sitting on a Roadster shop chassis with an LS3/TKX.211910
MachineADDICT
02-07-2024, 03:57 PM
crazyyyy happy for you [emoji41][emoji41]. You’ve also done quite well with it, look for ward to seeing how it turns out
XLexusTech
02-08-2024, 03:26 AM
DM me I need a new project.
XLexusTech
02-08-2024, 05:54 AM
Tried to DM but poster donet accept them
Hey just noticed your post. Curious what the staring point cost to purchase. In my youth I worked in a vette shop and always wanted one... I was looking at gen3 69-72 but would also do a Gen2 coup and go a similar route as you full chassis and LT conversion.
Just looking for a baseline for what a coup shell would cost me.
tflyboy77
03-15-2024, 03:01 PM
