Results 1 to 9 of 9
Thread: Manual brakes
- Join Date
- Oct 2022
- Posts
- 3
Manual brakes
Am I crazy for considering doing manual brakes on my Nova? The car will have a pretty healthy big block so I知 sure having enough vacuum will be an issue. I like the thought of how clean the firewall will be with a manual setup. I知 not a huge fan of the aesthetics of the hydroboost sticking out and extra lines running down to the power steering pump.
The car has 14 inch Baer rotors and 6 piston calipers on the front and 13 inch rotors with 4 piston calipers on the rear. Will there be any issues running this setup in a car that will see way more Street time and car show cruising than it will auto crossing.
10-29-2022 #2There is a thread "MC Recommendations" that would be a good starting point (I cant use Links). Have you had a car before with manual brakes? It can get tiring on the leg some times but overall I personally like them. If you set it up correctly I wouldn't see any problems.
10-29-2022 #3
