View Full Version : dual racing master cylinders
79T/Aman
10-22-2022, 11:39 AM
This dual master cylinder assembly was made to be a direct mount in place of the brake booster for an easy swap.
- Bolts in place of your car's original brake booster.
- Uses original pedals (new hole may be needed for proper pedal ratio )
- Adjustable pedal rod.
- Adjustable brake bias.
- 3 in 1 reservoir system.
- Available cockpit adjustable extension
- Brackets Available with or without clutch slave cylinder mount.
- Four bolt mounting reduces fire wall flex double that of others on the market or typical 2 bolt mount tandem master cylinders. (20 sq/in of firewall area VS 7 sq/in )
- The rocker mechanism increases pedal ratio by 1.6:1, facilitating the conversion from power brakes to manual unlike direct mount versions.
- On the shelf and ready to ship.
- $489.00, cockpit adjuster knobs $65.00
202944
[FONT=&quot[/FONT]
Jimmy Sean
10-25-2022, 07:04 AM
First Gen Camaro/Firebird Version?
79T/Aman
10-27-2022, 08:04 AM
Fits multiple vehicles.
dontlifttoshift
10-27-2022, 11:35 AM
Got a pic from the bottom side?
79T/Aman
11-04-2022, 02:19 PM
Installed in a 1st gen Camaro.
203260
