tcronkright
10-19-2022, 04:29 PM
1972 Pontiac Firebird - Track Inspired Build
Glad to be back in build mode with another Gen 2 Firebird!
I plan to take it up a few notches from my last Gen 2 build see: (https://www.pro-touring.com/threads/...in-Turbo-Build (https://www.pro-touring.com/threads/70621-1970-Firebird-Twin-Turbo-Build)) (http://egarage.com/car-profiles/1970-pontiac-firebird/) (https://www.motortrend.com/features/...tiac-firebird/ (https://www.motortrend.com/features/1109phr-1970-pontiac-firebird/))
I'm teaming up with the original crew of Kris Horton (www.carsbykris.com (http://www.carsbykris.com/)) for design and All Speed Customs (www.allspeedcustoms.com (http://www.allspeedcustoms.com/)) to make a track-dominating 1972 Firebird Formula. Here's the final design and build sheet below.
Looking forward to feedback and ideas as we progress!
[/LIST]
202895202896202897202898
Build Sheet:
ENGINE / RELATED COMPONENTS
GM LT4 650HP wet sump engine
T56 6-Speed transmission
Harness, pedal and ECM
Billet Black accessory drive with 140 amp Alt., P/S pump and A/C compressor
Be Cool Radiator module dual pass
Twin Spal electric fans
Aluminum aftermarket intercooler heat exchanger
Intercooler heat exchanger pump
Ultimate Headers Stainless LT4 swap headers black ceramic coated
CHASSIS / BODY COMPONENTS
ROADSTERSHOP SPEC CHASSIS
Engine set back 3" to distribute weight
DSE mini tub kit
Billet black air frame hood hinge set
Billet door hinge set anodized black
Billet trunk hinge kit with gas piston anodized black
Flush fit front and rear glass
BRAKES / RELATED COMPONENTS
Wilwood Aero 6 front brake kits 15" rotors 6 piston black calipers
Wilwood Aero 4 rear brake kit 14" rotor 4 piston black calipers w/parking brake
Wilwood Stainless DOT front brake flex lines
Wilwood rear parking brake cable kit
Wilwood Tandem master cylinder with proportioning valve black finish 1 1/8"
Hydratech hydroboost brake assist unit with 4' line set
PSC Motorsports P/S reservoir for hydroboost black finish
INTERIOR / WIRING RELATED COMPONENTS
[LIST]
Vintage AIR Gen IV Magnum builders Kit
Eddie Motorsports Odyssey billet battery (https://www.optimabatteries.com/en-us/redtop-starting-battery?utm_source=ProTouring&utm_medium=Display&utm_campaign=FY%2719_Brand_Media&utm_content=RedTop) trays
DSE Multi speed wiper motor kit
American Autowire Highway 22 universal wiring harness
NuRelics power window motors
Dakota Digital rtx series gauges
[/LIST]
Build Sheet:
DSE mini tub kit
[LIST]
