View Full Version : dakota digital installation
viperman
10-13-2022, 04:21 AM
Has anybody replaced their factory gauges with the DD setup in a 69 camaro? Did you have to remove the cluster, dashpad, etc... or can you do it easier by just removing the current setup. I just had the dash pad adn gauge bezel replaced, would hate to have to undo all that work....also it looks like you can work around the streering wheel and column....maybe a little more tricky, but less work ...looking for any advice...I am lookng at the rtx gauge package. Thanks, JR
dhutton
10-13-2022, 05:04 AM
Pretty sure you have to remove dash pad, lower column and remove cluster. At least that is the way I have done it. It may be possible to do it the way you describe but I have some doubt.
Don
