ModernMuseum
09-20-2022, 12:25 PM
I have a SPAL (model # AS80V4.2) keyless door and alarm system that came with an alarm module, harness and door lock solenoids which I installed about 10 years ago. I'd like to add a manual lock/unlock switch to it so I don't have to use the keyless buttons inside the car, but the instructions are sketchy. It looks like it will accommodate a 6-pole switch, but I'm not sure which one to get. I'd like to get one with a similar style to this one (low profile is better):
This appears to be the manual:
https://fccid.io/KNF-TX3G2/User-Manual/Manual-222988.pdf
Question: Will this type of switch work? Are there any general rules of thumb to wiring these things up?
https://www.a1electric.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=AEOS&Product_Code=DLSW-1
202225
The following diagram is in the manual, which lists 6 wires (for universal lock systems), but I doubt I'll be able to easily marry the two instructions to figure out the wiring.
https://static1.pt-content.com/images/pt/2022/09/VFgY7Gln_t-1.png (https://imgbox.com/VFgY7Gln)
202225
